Showing that a particular G_delta set exists with a measure property
jdinatale
Ok, I don't think I'm on the right track here. I ASSUMED that the set of all countable collections \{I_k\}_{k = 1}^\infty of nonempty open, bounded intervals such that E \subseteq \bigcup_{k = 1}^\infty I_k is a countable set itself, which it probably isn't.
I'm not even sure where to start on this problem. I feel like I need to use the assumption that E is bounded. I know if E is bounded, then E can be covered by a finite number of nonempty open, bounded intervals.
It's not. If you had a countable family of covers of this type, could you show that their intersection was a G_\delta set? Presumably that's the direction that you were going with this part of the argument. Then you'd at least have a G_\delta cover, and all that is left is to rig it so that it has the correct measure.
You have a decent start. You just don't have any control (measure-wise) over your covers. You need to use the assumption that E is bounded to get that control. If E is bounded, what can you say about its outer measure?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
