Doppler Effect: Speed Relative to Ground, Source, or Listener?
The Doppler Effect formula requires the speeds of the listener (VL) and the source (Vs) to be relative to the air, not the ground or each other. If the air is stationary, then the speeds are considered relative to the air itself. This distinction is crucial for accurately applying the Doppler Effect in various scenarios. Understanding this relationship helps clarify how sound waves behave when the source or listener is in motion. Accurate application of the formula is essential for precise calculations in physics and engineering.
Bassel
hi i just want to ask about the formula of Doppler Effect . The speeds of the listener VL and the source Vs are relative to the ground, source, or listener ?
If the air is stationary relative to the ground (no wind to worry about), then the speeds of the listener and source will be relative to the ground.
Neither. It is relative to the air.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
