Can you 'increase pressure' by restricting fluid flow?
The discussion centers on the misconception that restricting fluid flow increases pressure, using the analogy of putting a thumb over a garden hose. Participants clarify that while pressure may increase locally due to stagnation, the overall dynamics of lift generation in aerodynamics are governed by Bernoulli's principle and Newton's laws. They emphasize that the pressure under a wing does not simply remain the same as ambient pressure; it can vary depending on airflow conditions. The conversation critiques the oversimplified analogy and highlights the complexities of fluid dynamics, particularly in relation to viscous effects and pressure gradients. Ultimately, the example used to explain lift generation is deemed inadequate and misleading.
Doug1943
I just read this, from a site dedicated to popularizing science:
" ...think of air as being like water. If you have a garden hose and put your thumb over the end, the pressure increases and water sprays out. Same thing with air. Except the increased pressure is under a plane's wings and keeps it up."
Surely this has it all backwards? Bernoulli's principle, etc...
Well, it would be only a relative increase of pressure. I expect the pressure under the wing remains the same while the pressure over the wing is reduced because it is moving faster (Bernoulli's principle). This gives the net upward force of lift.
Yeah that article clearly doesn't have any idea what it is talking about. The phenomena leading to the generation of lift is largely different than anything you can demonstrate with a garden hose other than simply the relationship of pressure and velocity, which the article also apparently gets wrong. Up against your thumb there is certainly a pressure increase since the flow is stagnating against your thumb. The pressure in the moving stream of water decreases as it accelerates around your thumb, however, so I don't really know what the author here is talking about. Further, the pressure under an airfoil that holds it up is static pressure, not stagnation pressure, so it is an entirely different phenomenon from what you feel on your thumb in the example.
The pressure under a wing absolutely does not remain the same as ambient. It is often slightly higher than ambient pressure, but can under circumstances be lower than ambient pressure or roughly the same. There is nothing saying it has to be the same. The pressure over the upper surface is substantially less than ambient, however.
Likes Mohunk
First in the case the garden hose, the source of the pressure in the hose comes from the water company that pumps water into your household. The decrease in pressure (called head loss) over a length of hose is related to the speed^2 of the flow. Restricting the flow reduces the velocity of the flow and reduces the decrease in pressure. Wiki articles:
http://en.wikipedia.org/wiki/Hydraulic_head#Head_loss
http://en.wikipedia.org/wiki/Darcy–Weisbach_equation
This is not how wings function. A wing generates lift by diverting the relative (to the wing) air flow downwards. Some common laws of physics are involved. Netwon's third law pair of forces: the wing exerts a downwards force onto the air, coexistant with the air exerting an equal in magnitude and upwards force on the wing. Newton's second law, force equals mass time acceleration. In level flight, the downwards force exerted by the wing onto the air results in downwards acceleration of the air. Bernoulli principle, air accelerates from higher pressure areas towards lower pressure areas, and during the transition, if no external (to the air) forces are involved, then Bernoulli equation relates the increase in velocity to the decrease in pressure as the air accelerates from a higher pressure area to a lower pressure area. Bernoulli doesn't explain how those higher and lower pressure areas are maintained, but those require external (to the air) forces.
A conventional sub-sonic wing reduces pressure above a wing more than it increases pressure below, but using the air as a frame of reference, a wing increases the total mechanical energy of the air, which violates Bernoulli. Generally at the trailing edge of a wing, where the flows above and below a wing merge, there's a net increase in pressure that translates into increased downwards acceleration of the air until it's pressure returns to ambient. How much of an increase in energy of the air versus the amount of lift generated is related to the efficiency of a wing.
The example is awful but I'd also suggest people avoid using Bernoulli's principle in what is clearly a viscous application of a pipe flow driven by a pressure gradient. Putting your thumb over the end will increase the pressure just upstream of the obstruction, and then lead to a steeper pressure gradient through the pinch point. Flows in pipes have substantial viscous effects, and you cannot apply the standard Bernoulli "constant upstream velocity" if you're going to put your thumb over the end.
Sure you can... carefully. I agree with you overall, particularly in the fact that putting your thumb over part of the end will increase the pressure and it is not in violation of Bernoulli's principle, and I agree that Bernoulli's principle doesn't really apply over the length of the hose since it is a highly viscous situation. That said, the reason the pressure is going to increase in the vicinity of your thumb is not related to viscosity, but stagnation flow, and very locally along a streamline the viscous losses are going to be negligible, so Bernoulli's equation would give a very good approximation along that streamline and is still reasonably useful, especially conceptually.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
