Can I Use Functions Within Functions for Integration?
  • Thread starter Thread starter member 392791
    Functions
Functions can be nested within each other for integration, allowing for expressions like f(P) where P is a variable of integration. The example of integrating \int \sin(x^2) d(x^2) demonstrates that this approach is valid, yielding -\cos(x^2). However, integrating \int \sin(x^2) dx does not yield the same result, highlighting the importance of the variable of integration. This discussion relates closely to the method of "u-substitution," which facilitates the integration of composite functions. Understanding these concepts is crucial for accurate integration in calculus.
member 392791
Hello,
I am curious, suppose I have a function of x, f(x). Suppose I also have another function P(x). Does this mean I am allowed to have f(P) and I can do standard methods of integration and such on it?
Mathematics news on Phys.org
If P is the variable that you are integrating. For example, \int \sin(x^2) d(x^2) can be computed the way it seems you want to compute it. That is, \int \sin(x^2) d(x^2) = - \cos(x^2). However, \int \sin(x^2) dx \neq - \cos(x^2). The question you are asking has a lot to do with the integration method known as "u-substitution." Do you know what that is?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
