What is the Eigenvalue for a Harmonic Oscillator?
Habeebe
The Hamiltonian for a particle in a harmonic potential is given by
\hat{H}=\frac{\hat{p}^2}{2m}+\frac{Kx^2}{2}, where K is the spring constant. Start with the trial wave function \psi(x)=exp(\frac{-x^2}{2a^2})
and solve the energy eigenvalue equation \hat{H}\psi(x)=E\psi(x). You must find the value of the constant, a, which will make applying the Hamiltonian to the function return a constant time[sic, I assume he meant "times"] the function. Then find the energy eigenvalue.
Application of the Hamiltonian gave me:
\hat{H}\psi(x)=[\frac{h^2}{2m}(\frac{1}{a^2}+\frac{x^2}{a^2})+\frac{1}{2}Kx^2]\psi(x)=E\psi(x)
If I understand the problem correctly, since E and a must be constant, I must come up with an a, devoid of any x's or functions of x's so taking the Hamiltonian will yield something equally devoid of x's and functions of x's.
I mean, I get that I should have [\frac{h^2}{2m}(\frac{1}{a^2}+\frac{x^2}{a^2})+\frac{1}{2}Kx^2]=E for some constants E, a. The problem is, I have no clue how to go about solving that and getting a to not involve any x's, nor am I convinced that it's possible. Using the quadratic formula on it gives a big mess (involving x), so I'm pretty sure that's the wrong route.
Thanks for the help.
You have a sign error: How is the operator \hat{p} defined?
To remove x from the equation, collect the terms with x2. You have to choose the parameter a properly, so as the two terms cancel each other.
ehild
Likes 1 person
Also check to see if you have enough factors of ##a## in the denominator of your ##x^2/a^2## term.
Thanks, I found the sign error and got it worked out. As for the factors of a, you're right, I actually typed it in wrong.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
