Action Reaction on a discus thrower.
The discussion focuses on the physics of a discus thrower, particularly the action-reaction forces at play when the discus is released. It emphasizes that while simplifying the problem to a spinning arm with a mass, the dynamics change when considering the actual act of throwing rather than merely letting go. The conversation explores scenarios like standing still or running while throwing, highlighting that these actions produce action-reaction forces. Additionally, it examines a hypothetical platform in space with two spinning arms, questioning whether the platform would move upon the release of the masses. Ultimately, the principle of momentum conservation indicates that the platform would experience a net movement in response to the thrown discus.
imanator
Hi there,
I am trying to understand the physics acting on a discus thrower, namely at their feet when they throw a discuss.
first the player spins to pick up momentum for the discus, he or she does this by pushing on the ground but when the actual discus leaves the hand, is there an action reaction? isn't the discus just leaving their hand? if you were to simplify the problem to just a spinning arm on a pivot with a mass at the end, when the mass leaves the arm, does it push back on the arm, does the pivot feel the tangential force back?
In other words if the discus arm was in space or on water, assuming you could spin it up, when you release it, would the arm be flung back? would the displacement of the pivot change? not in a circle but linearly?
For that simplified problem, there is no tangential force. But you have made the problem too simple. You don't just "let go" of the discus, you "throw" it.
Think about some simpler situations first:
1. What are the action reaction forces if you stand still, and throw the discus?
2. What if you run forward in a straight line, and throw the discus while you are running?
In the real discus throw, you "run" in a circle to increase your angular velocity before you throw.
Thanks Sci Advisor. I am interested in this simplification.
Suppose I had a platform in space, with this apparatus(spinning arm on a pivot and a mass on the end) bolted on to the platform, and that I put another similar apparatus above it spinning in the opposite direction so that the platform has no net rotation in space. Now if I release the masses so that they both travel in the same direction, will the platform move when the balls are released? is there a reaction that the platform experiences?
when I say does the platform move, I mean a net movement, clearly the platform will oscillate while it is spinning.
I don't think the spinning matters. When you "throw" from a platform in space, whether by fling, by compressed air, or by a spring, momentum is conserved. m*v of projectiles and m*v of platform are equal and opposite. The same basic thing is true for the discuss thrower in spite of all the pre and post throw motion.
Thanks, so are you saying the platform will move back, or the momentum is conserved in the spinning, and the platform stays where it is?
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
