What Are the Requirements for Part B?
  • Thread starter Thread starter Logistics
Part B requires an understanding of heat transfer through conduction, specifically using the formula Q/t = dTKA/x. The key variables include Q/t as the heat current, dT as the temperature difference (140 in this case), K as the thermal conductivity (0.04), A as the cross-sectional area, and x as the length of the cross-section. Clarification on the question helped the user find the answer they needed. Understanding the formula and its components is essential for solving the problem.
Logistics
Could someone tell me what I'm supposed to do for part B please. I don't know what the question is asking :(
http://people.mail2me.com.au/~benogorancic/que.JPG
This question is with regards to the heat transfer through conduction.
Heat Current means Total heat energy liberated per second.
Go for the formula:
Q/t=dTKA/x
Where Q/t=heat current
dT=difference in temeperatures on both side of the walls(140 in the question)
K=Thermal conductivity=0.04 (given)
A=Area of the cross section
x=length of the cross section
Thanks I got the answer, I just needed to understand what PartB was asking
