OC Signal Processing Textbook Recs Requested
For those seeking recommendations on textbooks in the fields of Signals and Systems, Digital Signal Processing (DSP), and related areas, several key texts are highlighted. "Signals and Systems" by Oppenheim and Willsky is noted as a standard reference, though it lacks coverage of DFTs and FFT algorithms. The second edition corrects earlier conventions, making it suitable for those focused on signal processing rather than circuit analysis. "Linear Systems and Signals" by Lathi is also recommended for its inclusion of DFTs and basic FFT algorithms, although it has some limitations in feedback stability discussions.In the DSP category, "Digital Signal Processing" by Proakis and Manolakis is favored for its comprehensive coverage and problem sets, while "Discrete Time Signal Processing" by Oppenheim and Schafer is also a solid choice. The importance of mastering Signals and Systems for electrical engineering students is emphasized, with a focus on developing a deep understanding rather than just procedural knowledge.
Bipolarity
I was wondering if anyone can recommend me texts any or all of the following topics:
- Signals and Systems
- Digital Signal Processing
- Digital Audio and Speech processing
- Digital Image processing
- Digital Video processing
Would prefer if replies came from people who have perused through several textbooks on the field.
Thanks!
BiP
For signals and systems
"Signals and Systems" by Oppenheim and Willsky is the standard book. It primarily has one downside, and that is it doesn't cover DFTs and FFT algorithms (if you will be getting a DSP book as well then this does not matter at all). It emphasizes systems and signal processing more than circuits and differential equations, so it is probably the best fit for your interests assuming you will get a DSP book as well. The first edition uses a wacky convention for the lower limit of the single sided Laplace transform (0+ instead of 0-), but this is fixed in the second edition. Since you seem most interested in signal processing that is probably irrelevant and the 1st edition would be fine.
"Linear systems and signals" by Lathi is my favorite, as it includes DFTs and the simplest FFT algorithm, and includes more on differential equations and circuits, and actually includes sections on system realization. But the sections on feedback stability are lacking. Includes a chapter on state space techniques which are not necessary for such a book in my opinion. Probably not the one for you, but I really like it so I wanted to "plug" it :)
DSP:
"Digital Signal Processing" by Proakis and Manolakis is my favorite. I own the 3rd edition. Has standard topics, lots of good problems, and chapters on things like optimal filtering and spectrum estimation. I like it better than "Discrete time signal processing" by Oppenheim and Schafer, but both are good and you couldn't go wrong with either.
Again, used copies can be found cheap.
Note that signals and systems is one of the most important classes for an EE, in my opinion. Take the time to learn it well, and you will find that you seldom need to reach for a book. make sure you learn understanding/intuition, and not just how to manipulate Fourier/Laplace/Z transforms.
jason
The book is fascinating. If your education includes a typical math degree curriculum, with Lebesgue integration, functional analysis, etc, it teaches QFT with only a passing acquaintance of ordinary QM you would get at HS. However, I would read Lenny Susskind's book on QM first. Purchased a copy straight away, but it will not arrive until the end of December; however, Scribd has a PDF I am now studying. The first part introduces distribution theory (and other related concepts), which...
I've gone through the Standard turbulence textbooks such as Pope's Turbulent Flows and Wilcox' Turbulent modelling for CFD which mostly Covers RANS and the closure models. I want to jump more into DNS but most of the work i've been able to come across is too "practical" and not much explanation of the theory behind it. I wonder if there is a book that takes a theoretical approach to Turbulence starting from the full Navier Stokes Equations and developing from there, instead of jumping from...
