Choosing a generator for mini wind turbine
To choose a generator for a horizontal axis mini wind turbine, it's essential to select a DC motor that operates efficiently at a target wind speed of 25 mph while also generating power at lower speeds. The calculations indicate a maximum power output of 9 watts at 25 mph, based on the Betz limit and the swept area of the blades. When evaluating motors, consider specifications like voltage, torque, RPM, and current at maximum efficiency, as these will impact performance under load. It's crucial to understand that the motor will experience reduced blade speed due to the load, affecting overall efficiency. Proper mathematical assessment of the generator's specifications in relation to expected wind conditions is necessary for optimal performance.
carbs
Hello physics forum,
I am currently trying to figure out how to pick a generator for a horizontal axis mini wind turbine based on specs. I plan on buying a DC motor to use as a generator with blades directly attached to motor shaft. My goal is for the motor to be most efficient at 25mph wind speed, but also be able to generate power at lower wind speeds.
Diameter of blades: 6"
Wind speed from 0 to 25mph
My calculations so far:
Max power = 9 watts @25mph wind speed w/ perfectly efficient blade using equation: P=0.5*0.593*ρ*A*v^3
where P is power (W), 0.593 is Betz limit, ρ is air density (kg/m^3), A is swept area of blades (m^2), and v is wind speed (m/s).
Is there any way to approach buying a generator mathematically?
Some specs sheets on motors I see have voltage/torque/rpm/current@max efficiency, and stall torque/current.
Thanks!
The motor will make the blades spin slower than the same conditions without the blades.
You want to assess how much the motor with load the blades against he sort of winds you expect to operate in.
The motor ratings are for driving the motor.
Also see:
https://www.physicsforums.com/showthread.php?t=435164
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
