Moment of Inertia Using Parallel Axis Theorem
The moment of inertia of a cube about an axis through its center and the center of two opposing faces is given as (1/6)mQ^2. To find the moment of inertia when the axis is along one face of the cube, the parallel axis theorem is applied. The distance d from the center to the face is correctly identified as Q/2. The calculation results in Pface being (5/12)mQ^2. The final expression for the moment of inertia along the face of the cube is confirmed as accurate.
woaini
Q is the edge length of the cube. The moment of inertia of the cube about an axis passing through its center and the center of two opposing faces is (1/6)mQ^2 (PCM in the diagram). Use the parallel axis theorem to find the moment of inertia if the axis is along one face of the cube (Pface).
PCM=(1/6)mQ^2
Pface=?
d=?
Pface = PCM+md^2
d=(1/2)Q^2
Pface=\frac{mQ^2}{6}+\frac{mQ^2}{4}
Pface=\frac{5mQ^2}{12}
PCM=(1/6)mQ^2
Pface=?
d=?
Pface = PCM+md^2
d=(1/2)Q^2
Correct...except d = Q/2
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
