Physics Website: Find Answers to Questions
  • Thread starter Thread starter joejo
    Physics
The discussion revolves around a student seeking help with physics problems related to heat energy, specific heat capacity, and power calculations. Key questions include calculating the heat energy needed to boil water, determining the specific heat of an unknown substance, and finding the equilibrium temperature when mixing water at different temperatures. Participants emphasize understanding the units involved in each problem and suggest using formulas related to heat and energy. The student expresses confusion about the assignment's relevance to their grade 11 physics course and requests additional resources for better comprehension.
joejo
Hi guys...
My teacher for my online course gave me an assignment. But never gave us notes/lessons on the questions asked. I will list a few below and I was wondering if someone could please give me some links where I can find some information that will help me understand how to answer these questions.
Amy pours 1 kg of water at 7.0 ° C into a bowl. Calculate the amount of heat energy needed to bring this water to a boil. The specific heat for water is 4186 J/kg. ° C.
A block made of an unknown substance has a mass of 1.5 kg and a temperature of 15.0 ° C. When 2.6 x 104 J of heat is added to the block, its temperature rises to 90 ° C. Calculate the specific heat capacity to the unknown substance
When 1 kg of water at 1000C is mixed with 10 kg of water at 00C, the equilibrium temperature will be
Calculate the amount of heat energy required to boil 1.0 kg of water at 100 ° C into steam at 100 ° C. The latent heat of vaporization for water is 2.26 x 106 J/kg
An elevator motor lifts the elevator full of passengers to a height of 12 m in 30 s. If the mass of the elevator and passengers is 1000 kg, what is the power developed by the motor
The efficiency of an incandescent light bulb is only 4.0%. Calculate the amount of electric energy that must be input to the bulb in order to get 100 J of light energy from the bulb
Look at the units. "specific heat" is \frac{Joules}{Kilograms*degrees C}. the problem ask for energy (which is in "Joules"). In order to "cancel" the kg and degrees C in the denominator, you need to multiply that "fraction" by some number of kilograms and some number of degrees. You are given "1 kg of water" and you must raise it from 7 degrees to 100 degrees (in other words raise its temperature by 93 degrees) to bring it to a boil. What do YOU think you should do?
As before: specific heat is \frac{Joules}{kg*degrees C}. You are given Joules, kg and a rise in temperature from 15 degrees to 90 degrees, an increase of 75 degrees. What do you think you need to do to calculate the specific heat?<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> When 1 kg of water at 1000C is mixed with 10 kg of water at 00C, the equilibrium temperature will be? </div> </div> </blockquote> I think you MEANT 100 degrees C and 0 degrees C. At 1000C, it wouldn&#039;t <b>be</b> water! Since these are both water, you don&#039;t need to worry about different &quot;heat capacities&quot;. This is really just a &quot;weighted average&quot; problem.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Calculate the amount of heat energy required to boil 1.0 kg of water at 100 ° C into steam at 100 ° C. The latent heat of vaporization for water is 2.26 x 106 J/kg </div> </div> </blockquote> Once again, look at the units: &quot;latent heat of vaporization&quot; is \frac{Joules}{kilogram}. To &amp;quot;cancel&amp;quot; the kg and get only Joules (heat energy), you will need to multiply by some number of kilograms. How many kilograms are involved here?&lt;br /&gt; &lt;br /&gt; &lt;blockquote data-attributes=&quot;&quot; data-quote=&quot;&quot; data-source=&quot;&quot; class=&quot;bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch&quot;&gt; &lt;div class=&quot;bbCodeBlock-content&quot;&gt; &lt;div class=&quot;bbCodeBlock-expandContent js-expandContent &quot;&gt; An elevator motor lifts the elevator full of passengers to a height of 12 m in 30 s. If the mass of the elevator and passengers is 1000 kg, what is the power developed by the motor &lt;/div&gt; &lt;/div&gt; &lt;/blockquote&gt; &amp;quot;Power&amp;quot; is energy divided by time (work per unit time). If you raise 1000 kg 12 meters, what is the work done? If that is done in 30 s, how much work is done per second?&lt;br /&gt; &lt;br /&gt; &lt;blockquote data-attributes=&quot;&quot; data-quote=&quot;&quot; data-source=&quot;&quot; class=&quot;bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch&quot;&gt; &lt;div class=&quot;bbCodeBlock-content&quot;&gt; &lt;div class=&quot;bbCodeBlock-expandContent js-expandContent &quot;&gt; The efficiency of an incandescent light bulb is only 4.0%. Calculate the amount of electric energy that must be input to the bulb in order to get 100 J of light energy from the bulb &lt;/div&gt; &lt;/div&gt; &lt;/blockquote&gt; If the efficiency is 4.0%, then the amount of light put out is only 4% of then energy input: 0.04*energy input= 100J. Solve for the energy input.
thanks for your help guys...this is grade 11 physics...its not in our outline...but i don't know why were doing it...
but is there a site...there will help me understand it more...listing all the formulas
anyone please??
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
