Rotational Kinematics - Angular Acceleration
The discussion revolves around calculating the angular deceleration of a phonograph turntable that initially spins at 78 rpm and continues for 40 rotations after being switched off. The initial attempt at solving the problem results in an angular deceleration of -76.05 rpm², which is later identified as incorrect due to unit conversion errors. The correct conversion to rad/s² yields an angular deceleration of approximately -0.84 rad/s². Participants clarify the importance of squaring the time unit during conversions and discuss the correct approach to unit conversion. Ultimately, the focus is on ensuring accurate unit conversions to arrive at the correct angular acceleration value.
nx01
A phonograph turntable with an initial angular velocity of 78 rpm continues turning for 40 rotations after being switched off. What is the angular deceleration of the turntable? Assume constant angular deceleration.
\alpha=(\omega-\omega0)/t
θ-θ0=1/2(\omega0+\omega)t
t = (40 rot - 0 rot) / 1/2(78 rpm + 0 rpm) = 40/39 min
\alpha = (0 rpm - 78 rpm) / (40/39 min) = -76.05 rpm2
The answer needs to be in rad/s2
(-76.05 rpm2)(2∏ rad/rot)(min2/s2)=-7.96 rad/s2
The back of the book tells me this answer is incorrect. I would appreciate any insight into the error(s) I am making.
Thank you!
sure you made the right unit convertion? I get 0.84 rad/s^2 is that what you needed? Else I think the mistake lies elsewhere.
Hi hjelmgart,
Thanks for your reply. I'm pretty sure that my error lies in the unit conversion - did you do what I did in the conversion in the original post, or something else?
Not entirely. I don't understand how you reached that result also. rpm = rev/min
(1/min)^2 = 1/(60min/s)^2
rev^2 = (2*Pi)^2
Likes 1 person
Ah, I wasn't squaring the seconds unit when converting. Thanks!
