Is a surface plasmon an EM wave?
Surface plasmons (SPs) are electron oscillations induced by incident electromagnetic (EM) waves, and they can couple with photons to form surface plasmon polaritons (SPPs). There is confusion regarding whether SPPs and SPs are the same, as some sources use the terms interchangeably. While SPPs involve coupling with photons, they are not considered pure EM waves because they require a medium for propagation and exhibit mechanical wave characteristics. The interaction between EM waves and electronic excitations is typically reflected in the medium's refractive index. Ultimately, SPPs cannot be classified as pure EM waves due to their dependence on matter for propagation.
Aziza
From my understanding, surface plasmons (SPs) are oscillations of electrons caused by incident EM waves. A photon from the EM wave can couple with a plasmon to create a surface plasmon polariton (SPP). Some books/websites use the words SPP and SP interchangeably, so I am confused as to whether they really are the same thing or not. I am not sure what this 'coupling' really is. My friend assures me that SPPs are actually EM waves since they are coupled with photons, but I think they are still just mechanical waves since they cannot propagate through vacuum and are longitudinal, at least to my understanding. Does anyone know what exactly is coupling, and if this really does cause something to act as an EM wave, if the coupling is done with a photon??
Any EM wave propagating in a medium will couple to electronic excitations. These effects are usually subsumed in the refractive index n of the medium. The relative proportion of energy stored in the em field and in the medium varies with frequency and wavenumber. Usually there is only a small range of frequencies, where both mix considerably, the avoided crossing region. In books this is mostly discussed for phonon polaritons, but the principle is the same for surface plasmon polaritons.
See:
http://en.wikipedia.org/wiki/Polariton
See:
but then we cannot call them pure EM waves, correct? because they do need matter through which they can propagate
You are right, they are certainly not pure electromagnetic waves. However, nobody claims this.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
