What Is the Linear Oblique Asymptote of the Function (x^5+x^3+2)/(x^4-1)?
  • Thread starter Thread starter Coco12
    Asymptote Linear
The discussion focuses on finding the linear oblique asymptote of the function (x^5+x^3+2)/(x^4-1). The initial attempt concluded that the asymptote is y = x, but this was challenged as incorrect. It was clarified that to determine the oblique asymptote, one should perform polynomial long division, resulting in a linear equation plus a proper rational function. The correct approach emphasizes that the degree of the numerator must be greater than that of the denominator for an oblique asymptote to exist. Ultimately, the consensus confirms that y = x is indeed the correct linear oblique asymptote.
Coco12
what is the linear oblique asymptote of (x^5+x^3+2)/(x^4-1)
x-a/p(x) = q(x) +remainder
I put in all the placeholders for the divisor and the numerator and got x as the equation for the linear oblique asymptote?? Is that right??
We would let
\frac{x^5+x^3+2}{x^4-1}\equiv \frac{(ax+b)(x^4-1)+p(x)}{x^4-1} = ax+b + \frac{p(x)}{x^4-1}
Where p(x) is a cubic polynomial or less (doesn't matter what it is exactly).If we expanded (ax+b)(x4-1) then we get
ax^5+bx^4-ax-b
But we ignore the -ax-b term because that will be a part of p(x) which we've already said we don't care about. So we want the constant a to be chosen such that ax^5=x^5 since the coefficient of x^5 on the LHS must be equal to the RHS, hence a=1, and b must be chosen such that bx^4=0 for the same reason, hence b=0.
Is the answer that I got correct? Thanks for taking the time to answer. I know how to do it just wondering if it's correct
Yes, y= x is the "liner oblique asymptote".
No, this isn't correct. It's the equation of the rational function you started with.
To find the oblique asymptote, either do what Mentallic suggested or carry out the long division to get x + a proper rational function. In a proper rational function, the degree of the numerator is less than that of the denominator.
Ok thank you
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
