Couldn't understand the way the problem is solved regarding resistivit
  • Thread starter Thread starter Ein Krieger
The discussion centers on the relationship between the cross-sectional area and length of a wire during the process of wire drawing, where the volume of the wire remains constant. Reducing the cross-sectional area indeed increases the length of the wire, as the mass must remain constant according to the formula for mass (mass = density × volume). The confusion arises from the assumption that a reduction in area only affects the radius, while in reality, it also necessitates a proportional increase in length. The key takeaway is that as the cross-sectional area decreases, the length of the wire must increase to maintain a constant volume. Understanding this relationship clarifies the problem regarding resistivity and wire dimensions.
Ein Krieger
Hello,
I was observing the solution of the following problem below:
Below it says that reducing the cross-sectional area of the wire triples its length. However, according to cross-sectional area equation A=pi*r^2 we observe that reduction of area only leads to reduction of radius .
Is there a mistake or I have some gaps in knowledge regarding above mentioned relationship?
It says the wire is drawn out to reduce it cross section area. See http://en.wikipedia.org/wiki/Wire_drawing if you don't know what "wire drawing" means.
Assume the volume of the wire is constant. As you reduce the cross section area, you increase the length.
In the original configuration there is some fixed mass of wire. After stretching will there not be the same mass of wire? You need to make the wire longer to compensate for the loss in radius.
The wires mass before+
mass= ρ*Volume. the volume = A*L
so
Mass = ρAL
I will now let you find the length after stretching.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
