Proof of Angles: Does it Seem Correct?
  • Thread starter Thread starter chemistry1
    Angles Proof
The discussion focuses on a mathematical proof relating degrees and grads, starting with the conversion of 1 degree to 10/9 grads. The user generalizes this to x degrees equating to (10/9)x grads. The proof involves calculating the number of minutes in both degrees and grads, leading to a simplified fraction of 27/50. Feedback suggests avoiding mixed numbers for easier calculations, and an alternative simplification method is proposed. The proof appears to be validated by the participants in the discussion.
chemistry1
http://postimg.org/image/3mmlbro1p/
Hi, I just want to know if my proof seems ok.
So we can begin with :
1 degrees = 1+1/9 grads
we multiply by x to generalize
x degrees= x+x/9 grads
now, we take x degrees and multiply it by 60 minutes to know how many minutes it makes.We also do the same with x+x/9 grads but we multiply it by a 100 minutes. After, we put this form :
60x degrees/(100x+100x/9) grads
we simplify it :
60x/(1000x/9)grads
60x * 9/1000x
We cancel and simplify
3*9/50
Which finally gives us 27/50 for any 'x'.
Does this seem correct ? Thank you !
That seems to work. You can simplify the process by a few steps by doing
##\displaystyle\frac{60(x-\frac{x}{10})}{100(x)}## instead.
It's a bad idea to use mixed numbers like 1 + 1/9, because it makes the calculations more difficult.
1 deg. = 10/9 grads
x deg. = (10/9)x grads
we simplify it :
60x/(1000x/9)grads
60x * 9/1000x
3*9/50
Ok, thanks for the info !
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
