Optimizing Hybrid Vehicle Layout for Efficient City Driving
  • Thread starter Thread starter csiddharthn
    Vehicle
The discussion focuses on designing a hybrid vehicle optimized for efficient city driving, emphasizing the layout's compatibility with epicyclic transmission. Key considerations include selecting the appropriate clutch and determining the engine's efficient operating range. Additionally, the capacity of the battery must be balanced with motor power and vehicle weight for optimal performance. A suggestion is made to simplify the design by using the internal combustion engine to power a generator instead of a gearbox, allowing electric motors to drive the wheels directly. The conversation highlights the importance of balancing complexity and efficiency in hybrid vehicle design for urban environments.
csiddharthn
Hi guys,
There's a project on hybrid vehicles, and the task is to design and simulate a hybrid vehicle: we have started on the basics, and have come up with a small layout as to how the hybrid will look like. Our main concern is whether the layout will work just with the epicyclic transmission, with the connections shown in the picture attached, also how do you select the clutch and how do you decide on how to operate the hybrid at an efficient operating range of the engine?
Another question is how do you decide on how much capacity the battery should have with respect to 'motor power' and 'vehicle weight' considerations.
Guys please guide me on how to go about designing such a hybrid vehicle. The objective is load carrying through short distances in cities, at city speeds.
Thanks in advance.
If the goal is short distances at city speeds, your hybrid might be simpler and lighter if the IC engine was used to drive a generator, rather than a gear box. Then you could use electric motors to direct drive the wheels and eliminate the need for the gearing.
The Volt design is pretty interesting in that context, as the IC engine there can also drive the car, a bow to the need to have more than battery only range and power.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
