How Can We Calculate Displacement and Average Velocity for a Complex Trip?
  • Thread starter Thread starter negation
    Asteroid Earth
The discussion focuses on calculating displacement and average velocity for a car's complex trip involving three segments: driving north, then east, and finally southwest. The x and y components of the displacements were calculated, resulting in a total x-displacement of 2.88 miles and a y-displacement of 4.58 miles. There was some confusion regarding the interpretation of displacement versus total distance traveled, as well as a humorous aside about an unrelated asteroid reference in the title. The participants confirmed the calculations but noted that the final answer should include total distance and direction. The conversation highlights the importance of clarity in physics problems and calculations.
negation
A car drives north at 40mi/h for 10mins then turns east and goes 5min at 60mi/hr. Finally it goes southwest at 30mi/h for 6min.
a) determine the displacement
b)average velocity for this trip
x-component: 60mi/hr/60min x 5min = 5mi
y-component: 40mi/h/60min x 10mins = 6.7mi
south-west:
x-component:[(-30mi/hr cos 45°)/60mins]6min = -2.12mi
y-component: [(-30mi/hr sin 45°)/60mins]6min = -2.12mi
a) x-displacement: 5mi + (-2.12mi) = 2.88mi i
y-displacement: 6.7mi + (-2.12mi) = 4.58mi j
b)
hi negation! :smile:
south-west:
yes, that looks fine, except i think they expect you to finish by converting into a total distance and a direction :wink:
(by "direction" i don't know whether they want an angle, or whether specifying a unit vector would be enough)
(i assume you're ok on b)?)
EDIT: just noticed …
how does this save Earth from an asteroid?? :confused:
Correct me if I am wrong, but displacement means the distance between the starting point and the destination, therefore not the total ground covered.
Yeah, what does the asteroid have to do with it? :O
Sorry it was a careless blunder as to the title.
Question has been solved
careless blunder?!
it won't always be a practice! :rolleyes:
whole planets have been lost for less! :frown:
