Analysis - Show Linear functions are uniformly Continuous
dkotschessaa
Suppose f:R->R is a linear function. Prove from the definition that f is uniformly continuous on R.
Epsilon delta definition of uniform continuity: A function f:X->Y is called uniformly continuous if ##\forall\epsilon##>0 ∃x st. dx(f(P),(Q))<δ→ dy
I found this easier than I expected, so of course that makes me think I'm wrong. Also I'm not sure about the placement of the absolute value signs near the end.
let σ=f-1(ε)
|p-q|<σ→|p-q|<f-1ε → f(|p-q|)≤|f(p)-f(q)| < ε
Where f(|p-q|)≤|f(p)-f(q)| is due to the linearity of f.
What are P, Q, d_x and d_y?
The definition of uniform continuity for real functions is that f is uniformly continuous on U \subset \mathbb{R} if and only if for all \epsilon &gt; 0 there exists a \delta &gt; 0 such that for all x \in U and all y \in U, if |x - y| &lt; \delta then |f(x) - f(y)| &lt; \epsilon.
let σ=f-1(ε)
This step is not justified, since constant functions are linear but not invertible.
If f: \mathbb{R} \to \mathbb{R} is linear, then you must have f: x \mapsto ax + b for some a \in \mathbb{R} and b \in \mathbb{R}.
Now calculate |f(x) - f(y)|.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
