Express wave function in spherical harmonics
z2394
1. Problem:
I have a wave function ψ(r) = (x + y + z)*f(r) and want to find the expectation values of L2 and Lz. It is suggested that I first change the wave function to spherical coordinates, then put that in terms of spherical harmonics of the form Yl,m.
2. Homework Equations :
Spherical harmonics and conversions from Cartesian to spherical coordinates
3. Attempt at solution:
So I know how to express the wave function in spherical coordinates (which should be ψ(r) = r*f(r)*(sinΘcosø + sinΘsinø + cosΘ). I am having a hard time going from this to spherical harmonics though (I am sort of new to this). I can see from a table of spherical harmonics that Y1,0 does have a cosΘ, but how would I get the terms that have Θ and ø? (I can see that there are some spherical harmonics that have e, but this would give me cosø + isinø, so it doesn't look like that would get me what I want.)
Hi z2394,
The wavefunction can be written rf(r)sinθ[cosø + sinø] + rf(r)cosθ. As you said, the second term here can be written in terms of a single spherical harmonic. To get the first term as a linear combination of spherical harmonics, try expressing cosø and sinø in their complex exponential forms.
So I see how to do that now, and I get ψ(r) = r*f(r)*(\sqrt{2{\pi}/3}(-Y1,1+Y1,-1) - (1/i)\sqrt{2{\pi}/3}(Y1,1 + Y1,-1) + \sqrt{4{\pi}/3}Y1,0). But now how do I use this to get <L2> and <Lz>? I know to do <ψ| L2 |ψ> and <ψ| Lz |ψ>, but does L2 acting on ψ here still give me the l(l+1)h2 eigenvalue, and Lz the mh eigenvalue, (where h is actually the reduced Planck constant), when acting on this ψ?
When L2 and Lz act on the spherical harmonics, then the eigenvalue returned is l(l+1)h2 and mh respectively. First though, you will need to normalize ψ. Introduce some normalization constant, say A, and solve for A using the fact that the spherical harmonics are a complete set of orthonormal functions.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
