Is it possible to glow-discharge air at atmospheric pressure?
Glow discharge in air at atmospheric pressure is theoretically possible but challenging, as traditional high-voltage methods often lead to spark discharges rather than sustained glow. Research indicates that DC glow discharges can occur in atmospheric pressure air, as noted in studies like those by Zdenko Machala. The phenomenon of St. Elmo's fire, a type of coronal discharge, is often referenced but does not meet the criteria specified in the discussion. High-frequency high-voltage methods may offer potential for achieving a glow discharge, although practical applications remain limited. Overall, while the concept is intriguing, achieving a stable glow discharge in atmospheric conditions requires further exploration and innovation.
leviterande
Hi,
I know air can be made ionized and glow at low atmospehres like in vacuum tubes at high voltages. But is it possible to somehow make a glow discharge(not corona discharge out of leaking sharp edges) at atmospheric pressures?. Except of Ionization radiation- I haven't heared or read of this,? If it is possible what would do it? very HV van de graafs only produce gigantic spark discharges so simple hv direct current can never do it I guess. HV HF transformers also produce mostly spark discharges but a very tiny glow I suspect(?). Could in theory, HV at sufficient high frequency in the radio range at sufficient energy produce a glow discharge or what would happen??
Thanks
You seem to be asking if it is possible for any situation except for those very situations where it is possible.
A google for "glow discharge in air" yields a lot of possibles ...
This may be close to what you are looking for:
DC glow discharges in atmospheric pressure air
... Zdenko Machala et al, Journal of Advanced Oxidation Technologies
Yachting people speak of Saint Elmo's fire.
St. Elmo's fire (also St. Elmo's light[1][2]) is a weather phenomenon in which luminous plasma is created by a coronal discharge from a sharp or pointed object in a strong electric field in the atmosphere (such as those generated by thunderstorms or created by a volcanic eruption).
http://en.wikipedia.org/wiki/St._Elmo's_fire
leviterande said:
...not corona discharge out of ... sharp edges...
That's what I thought of too - however, OP has excluded it from consideration.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
