General Quantization of Motion in Circular Orbits
wawitz
For this question, I have to obtain a general quantization of motion in circular orbits by combining the equations (Where U(r) is potential energy):
(mv2)/r= |(dU(r))/dr|
With the angular momentum quantization of: mvr= nℏ
Then use this to calculate the spectrum for circular motion in a potential of U = F0r.
After combining these equations, along with E = Ke + Pe (for kinetic and potential energies), I obtained this equation:
En= 3/2*(n4/34/3 F02/3+F02/3 n2/32/3)/m1/3
The next step confuses me. To obtain a spectrum, I would have to use the relation ∆E=hc/λ; however this requires a difference of energies for ΔE. Would this mean setting up an equation for En+1 – En, using the equation I found for En?
Hello Witz and welcome to PF. There is a pretty strict rule here that you make use of the template. In this case even I can see the usefulness: you have to obtain a general quantization. That's what you have done, so you are finished.
Why contnue? What is triggering the spectrum adventure ?
(You have an idea, why not follow up on it?)
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
