Rayleigh Criterion or Resolving Power?
  • Thread starter Thread starter Sastronaut
    Power Rayleigh
The discussion revolves around comparing the diffraction limits of the Hubble telescope and a 100m radio telescope. It highlights that radio telescopes must be larger due to the significantly longer wavelengths of radio waves compared to optical light. The Rayleigh Criterion is confirmed to be synonymous with resolving power, emphasizing the relationship between wavelength and telescope diameter. The provided equation for resolving power illustrates this relationship quantitatively. Understanding these concepts is crucial for explaining the necessity of larger radio telescopes.
Sastronaut
I must compare the diffraction limit of the Hubble telescope (2.4 meter) observing 500nm and a 100m telescope observing radiowaves with a wavelength of 21cm. I am asked to then explain why radio telescopes must be bigger!
I understand why it must be larger (The wavelength of radio light is much larger than optical (on the scales of meters as opposed to nm), so to be able to resolve objects with small angular sizes, you have to use a much larger telescope), but my question pertains to Rayleigh Criterion. My professor never taught us this. My question is Rayleigh Criterion the same as RP power. The equation given to use for resolving power is (2.5x10^5)(wavelength of light/diameter of telescope)
Yes, the Rayleigh Criterion is the same as resolving power. Just compare (wavelength)/(diameter) in both of your cases.
Likes 1 person
