Air Flow through cooling tower- fluid mechanics problem
Improving the efficiency of natural draft counter flow cooling towers involves understanding air velocity and temperature profiles within the structure. Research indicates that air velocity decreases from the periphery to the center of the tower, while temperature increases, a finding supported by CFD simulations. The assumption that air velocity reduces as it approaches the center is deemed acceptable, with the hyperbolic shape of the tower potentially influencing the air velocity profile. The volume flow rate remains approximately constant across horizontal cross sections, although humidity changes may slightly affect air density. A diagram of the cooling tower's internal structure could clarify the airflow dynamics further.
Ritz_physics
Hey everyone!
I am working on improving natural draft counter flow cooling tower efficiency as my final year B.E. project. I came across a research paper that said that at transverse cross section of the tower, above drift eliminators, the air velocity decreases from the periphery to the middle of the tower, while the temperature increases. The statement is also supported by CFD simulation of the tower.
If viscosity effect is considered, the velocity at the periphery of the cross section of the tower should be less than that at the center. I am assuming that since the flow of air takes place from the edges of the tower at the bottom, the velocity must be progressively reducing as air approaches towards the center of the tower, than at the periphery. Is this assumption acceptable?
Also, could the hyperbolic shape of the tower have got anything to do with the influence on air velocity profile across tower section?
My first thought is, unless you expect compressible flow (which I would assume is not an issue on a cooling tower), the volume flow rate at any horizontal cross section of the tower would be constant. That is, the volume flow rate at the bottom, the volume flow rate at the narrowest point, and the volume flow rate at the top, will all be approximately equal. This might not be 100% true due to the change in humidity of the air as it evaporates the fluid that's being cooled, but the changes in air density due to the increase in humidity should be negligible. So, depending on what the inside structure of your cooling tower looks like (I've never seen one except on the internet, but there are different designs I think), the maximum velocity would always be at the center of the cooling tower, furthest away from the walls.
The exception to that is where the air intake is, it might be slower at the center of the tower than where the air intake is located. I hope that helps.
Oh wait, I think I understand now what you mean. In that case, the periphery where the intake is, the velocities would probably be...well, they would still be lower than the choke point at the center of the tower. So, a lot of slower moving air coming in from all around at the bottom of the cooling tower will equal faster average moving air at the center choke point of the cooling tower, where the cross section is more narrow.
I think, if I understand what you're saying, that's how I'd look at it. Though, admittedly, I don't really know what the inside of a cooling tower looks like or where the air flows exactly. A diagram might be helpful here if you have something you can post.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
