Need help with this difficult Integral involving exponentials
  • Thread starter Thread starter DiogenesTorch
    Integral
The problem involves evaluating the integral \(\int \frac{x^2}{e^x-1}dx\), with participants discussing the possibility of finding a closed form solution and exploring series representations.
  • Participants discuss integration by parts as an initial approach and consider series expansions for \(\frac{1}{e^x-1}\). Questions arise regarding the validity of the series solution and the nature of the integral (indefinite vs. definite).
Some participants suggest that a closed form solution may not exist and that the polylogarithm function might be necessary. Others indicate that series solutions are acceptable and inquire about the implications of the integral's boundaries.
There is a mention of the integral being relevant only for definite integrals over the range \(0
DiogenesTorch
This is the integral
[tex] \int \frac{x^2}{e^x-1}dx[/tex]
Can this even be solved in closed form?
Only method I can think of is integration by parts over numerous steps. I did that until I get the following:
[tex] \int \frac{x^2}{e^x-1}dx = x^2 \ln{(e^x-1)} -\frac{5x^3}{3}-2 \int x \ln{(e^x-1)} dx [/tex]
Now I am stuck on the last integral above: [itex]\int x \ln{(e^x-1)} dx[/itex] and can't find how to integrate it.
Any ideas or suggestions much appreciated :)
Is this acceptable?
Can we do this? If x is taken to always be positive then:
[tex] \begin{align*}<br /> \frac{1}{(e^x-1)} &= \frac{e^{-x}}{1-e^{-x}} \\<br /> &= e^{-x}\frac{1}{1-e^{-x}} \\<br /> &=e^{-x}\sum_{n=0}^{\infty}e^{-nx} \\<br /> &=\sum_{n=0}^{\infty}e^{-(n+1)x} \\<br /> &=\sum_{n=1}^{\infty}e^{-nx}<br /> \end{align*}[/tex]
Then subbing this series into the original integral
[tex] \begin{align*}<br /> \int \frac{x^2}{e^x-1}dx &= \int x^2 \Biggr( \sum_{n=0}^{\infty}e^{-(n+1)x} \Biggr) dx \\<br /> &= \sum_{n=0}^{\infty} \int x^2 \Biggr( e^{-(n+1)x} \Biggr) dx \\<br /> &= \sum_{n=1}^{\infty} \int x^2 e^{-nx} dx<br /> \end{align*}[/tex]
You cannot solve it in closed form, you need the polylogarithm function. You can find series solutions though.
Thanks micromass,
So is the series solution above okay are am I totally off on it?
DiogenesTorch said:
Thanks micromass,
The series solution looks fine, I don't think you can express the result of final integral without the help of error function. Note that the result is valid when ##0<x<\infty##.
Are you sure you were asked for an indefinite integral instead of a definite one?
Thanks Pranav.
Looking back this has to be only for definite integrals as ##x## was a change of variable for a frequency relationship, ##x=\frac{\hbar\omega}{k_b T}##. So it has to be only for definite integrals over ##0<x<\infty##.
This integral has a solution if the boundary is from 0 to infinity but I do not know if this is relevant to you.
  • · Replies 105 ·
12K
  • · Replies 54 ·
18K
