Tangent to the circle at a given point
skrat
I basically have the radius of the circle and its displacement from the origin, so ##(x-p)^2+(y-q)^2=r^2##
And now I need to find a tangent to the circle at a given point ##(a,b)##. Or at least the slope of the tangent.
How would one do that?
If the circle had its center in the origin, than the slope of the tangent would be easily ##-\frac a b## but I am not sure. If the circle is not in the origin, is the slope than ##-\frac{a-p}{b-q}## or is it not?
Can you differentiate the circle's equation, then isolate dy/dx on one side of the equals sign?
If the circle had its center in the origin, than the slope of the tangent would be easily −ab
No. Try sketching the points, you'll soon see that's not a tangent.
Always sketch what you are dealing with!
##2(x-p)dx+2(y-q)dy=0##
##\frac{dy}{dx}=-\frac{x-p}{y-g}##
:D Easy as that!
THANKS
No easier but more elementary you could consider the equation of any line through (a, b). Apart from going through (a, b) what other condition does the problem require the line to satisfy?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
