Calculate Initial Angular Speed of Fan | High to Low Button Pushed
The discussion focuses on calculating the initial angular speed of a fan that decelerates from a high speed to a low speed after the LOW button is pressed. The fan's final angular speed is 98 rad/sec, and it decelerates at a rate of 42.3 rad/sec² over 1.83 seconds. Using these values, the initial angular speed can be determined through the kinematic equations for rotational motion. The radius of the fan blades is 0.62 meters, which is relevant for understanding the fan's physical dimensions but not directly needed for the speed calculation. The conversation emphasizes the straightforward nature of the calculation involved.
choole
An electric fan is running on HIGH. After fan has been running of 13.2 minutes, the LOW button is pushed. The fan slows down to 98 rad/sec in 1.83 seconds. The blades of the fan have a radius of 0.62 meters and their deceleration rate is 42.3 rad/sec2.
What was the initial angular speed of the fan in rev/sec?
--> Homework forum??
look at the second omega and alpha... its only one step to the solution...
edit: does seem to belong there eh pete?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
