Kinnersley Metric: Details, Form, Reference?
  • Thread starter Thread starter Markus Hanke
    Metric
Markus Hanke
In the Wiki article about the Vaidya metric :
http://en.wikipedia.org/wiki/Vaidya_metric
there is mention of a "further generalisation" called the Kinnersley metric, without giving any details or even a reference. Is this a generalisation of the Vaidya metric to include angular momentum ( i.e. a radiating Kerr or Kerr-Newman solution ), or is it something different ? Does anyone have a link to the specific form of the Kinnersley metric ?
I am really just curious, and somewhat disappointed about the poor quality of this particular Wiki page, and its lack of referenced sources.
The metric is known as Kinnersley's relativistic rocket. You can easily google it.
The Kinnersley photon rocket. Got it, and will do my own research into it. Thank you :)
See the interesting discussion in section 19.5.2 "Kinnersley's rocket" from the excellent book "Exact Space-Times in Einstein's General Relativity" by Jerry B. Griffits and Jiri Podolsky.
If ##\alpha = 0##, the metric (19.54) reduces to the Vaidya–(anti-)de Sitter spacetime
expressed in the form (19.51).
Thank you George Jones for the reference - unfortunately I do not own a copy of this text, but I will see what I can do to track down this book at a reasonable cost. Seems like a worthwhile investment !
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
