Do photons bounce into each other?
  • Thread starter Thread starter acesuv
    Bounce Photons
acesuv
if photons bounce into each other at a frequent rate, and photons bouncing off of each other may result in large change in direction of motion... then why don't we see "junk" photons? photons that enter our eye not because they bounced off a surface, but instead bounces off of another photon?
Photons don't bounce into one another. They cannot interact with one another directly. They can only scatter off one another indirectly (c.f. Delbruck scattering).
The term "collision" is often used in scattering theory but in that context "collision of particles" translates into "interaction of particles through some potential of finite range" so scattering doesn't necessarily entail an actual collision in the colloquial sense. It's a very poor but ubiquitous terminology.
Likes acesuv
Not in the conventional sense. Having no mass, they do not collide as other particles would, especially if you look on the macroscopic level. They do interact, but remember that they are bosons, not fermions. They can, and do, occupy the same physical space as other photons.
Likes acesuv
I found this an interesting question so poked around the internet a bit (acesuv, I encourage you to do a bit of your own research on questions like this) and found that you can even shoot laser beams through each other with basically no effect.
Likes acesuv
Likes acesuv
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
