Linewidths - Frequency and Wavelength
The discussion centers on the relationship between line widths in frequency and wavelength, highlighting a common confusion. It is noted that a broader spread of frequencies should correspond to a broader spread of wavelengths. The mathematical relationship derived from the equation c = fλ indicates that changes in frequency (df) and changes in wavelength (dλ) have opposite signs. This leads to confusion about why a positive change in frequency results in a negative change in wavelength. The conversation reassures that understanding this relationship is achievable with confidence in mathematical principles.
Naz93
Hi,
Probably a really stupid question... but I'm confused about how to relate a line width in frequency to one in wavelength. To me it seems obvious that if there's a broader spread of frequencies, there must be a broader spread of wavelengths, and vice versa - after all, the line is broader.
But... if you relate Δf and Δλ mathematically (f is frequency, since there was no nu on the quick symbols list):
c = fλ
f = c/λ
df/dλ = -c/(λ^2)
so df = dλ * (-c/(λ^2))
I.e. if df is positive, dλ is negative...
What am I doing wrong??
Where's the problem in that? One slope is positive and the other is negative - that's what you get when you have
λ= c/f and you write down dλ/df
No worries. Have faith in yourself and your maths.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
