Question about spectroscopic notation
The discussion centers on the notation used for multi-electron orbitals, specifically the notation ^{1}D_{2} and its variant ^{1}D_{2}^{0}. The notation ^{1}D_{2} indicates a singlet state with total spin S=0, orbital angular momentum L=2, and total angular momentum J=2. The additional superscript 0 in ^{1}D_{2}^{0} signifies odd parity, while even parity is indicated by the absence of a superscript. There is some uncertainty regarding the origins of this notation, particularly as it relates to Slater's work, which may reflect a physicist's perspective on spectroscopic data. The discussion acknowledges the potential confusion surrounding these notations and suggests that the odd parity may arise from specific configurations leading to a negative total spin value.
Kalimaa23
Greetings,
I'm a bit confused about the notation for multi-electron orbitals.
For example, you have the notation
^{1}D_{2},
which mean a singlet with S=0 L=2, J=2, right?
Now I've come across the notation (in Slater)
^{1}D_{2}^{0}
What's the deal with the extra superscript 0?
Chemistry news on Phys.org
The std. notation, as I'm sure you know is 2S+1XJ, where X = S,P,D,F.
I've also come across notation that appends nlx in front of the std. notation. Where this extra addition is simply the configuration of the outermost subshell.
I have no idea what notation Slater is using. But keep in mind that he is a physicist (and hence loathes spectroscopists despite feeding off their data :wink:) and nearly all his books were written in the 60s (or thereabouts).
Dimitri Terryn said:
^{1}D_{2},
This is correct. Until better info comes along, you can feel safe ignoring the 0.
The superscript o after the subshell indicates odd parity. When the parity is even, there is no superscript. I hesitate to venture further, because it's a little fuzzy to me as well. I think that the odd parity results if you get a negative value when summing spins, like if you have a total negative spin. This thread is so old, I don't know if anybody even cares.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
