Calculate the change in entropy of the system
The problem involves calculating the change in entropy of a system consisting of two aluminum cans filled with water at different temperatures. One can contains 485 g of water at 0°C, while the other contains 517 g of water at 48.5°C. The scenario assumes no heat exchange with the surroundings.
  • Exploratory, Assumption checking
  • Participants discuss the calculation of average temperature and the change in temperature for both sides to find heat transfer (Q). There is mention of dividing Q by the starting temperatures, and one participant expresses confusion about arriving at an incorrect entropy change value. Another participant suggests the need for integration due to changing temperatures during the process.
The discussion is ongoing, with participants sharing their calculations and expressing frustration over similar problems. One participant has provided a potential approach involving integration, indicating a productive direction for further exploration.
Participants mention having multiple similar problems, indicating a broader context of learning challenges related to entropy calculations. There is an emphasis on the need for clarity in the assumptions made regarding heat transfer and temperature changes.
squib
An aluminum can, with negligible heat capacity, is filled with 485 g of water at 0°C and then is brought into thermal contact with a similar can filled with 517 g of water at 48.5°C. Calculate the change in entropy of the system if no heat is exchanged with the surroundings.
1) I find avg temp, which turns out to be: ~298
2) I calc change in temp for both sides, and find Q. (deltaT)(4.184)(mass)
3) Divide each Q (they're the same, with one being negative) by each starting temperature
4) I come up with .163599 J/K, which is wrong
Where am I messing up? I have 4-5 problems identical to this but can't figure any of them out!
Can you show your calculations?
Since the temperature changes as the heat is absorbed/lost, you have to integrate:
[tex]\Delta S = \int_{T_i}^{T_f} dQ/T = cm\int_{T_i}^{T_f} dT/T = cm* ln(\frac{T_f}{T_i})[/tex]
AM
Thanks so much, I've been very frustrated with how to do those and couldn't find the answer ANYWHERE. Big thanks!
