Electron Detection spectroscopy
saiarun
In the electron detection using Silicon Detector ,Liquid nitrogen is used to cool the system . why is it used. What is "sweating" which is caused if the detector is not in vaccum,when kept in liq. nitogen
Thanking you in advance. :smile:
Hello--I don't know much about electron detection spectroscopy, but the reason why sensitive experiments are usually kept in cryogens (cooling the system) is to reduce thermal energy which might cause noise. (How does the electron detector work? Maybe the goal is to reduce thermal excitation of silicon electrons?) If the detector is not in vacuum but is cold, perhaps this "sweating" effect is just condensation of water from air?
I believe flip is right on both counts.
Simply put, you want to be at temperatures much smaller than the band gap, lest you excite thermally rather than by the incident electrons - hence the liquid nitrogen.
Sweating is merely the formation of condensation/frost on the outside of a cooled apparatus, that usually forms as a result of a thermal short to the (cooled) inside (often from insufficient evacuation).
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
