Polar Form of 6x^2 + 3xy + 6y^2 = -3 | 4 Answers
  • Thread starter Thread starter TonyC
    Forms Polar
The discussion focuses on converting the equation 6x^2 + 3xy + 6y^2 = -3 into polar form, with multiple users providing different answers. The key transformation involves using polar coordinates where x = r cos(θ) and y = r sin(θ), leading to the equation r^2(4 + sin(2θ)) = -2. It is noted that the resulting r^2 is negative, indicating that r is an imaginary number, which suggests no real solutions exist for the original equation. Users agree that some provided answers may be equivalent, but caution that the equation has no solutions when x and y are real numbers. The discussion emphasizes the importance of proper substitutions and transformations in achieving the correct polar form.
TonyC
I am working a problem:
Find the polar form of the equation 6x^2 + 3xy + 6y^2 = -3
I have run this 4 separate times and have come up with 4 different answers.
PLEASE HELP!
r^2= 6 over -6 - 3sin(theta)cos(theta)
r^2=-3 over 6 - 3sin(theta)cos(theta)
r^2=9 over 6 + 3sin(theta)cos(theta)
r^2=-3 over 6 + 3sin(theta)cos(theta)
:cry:
Don't make things hard.
recall (i an using t instead of theta)
x^2+y^2=r^2
2xy=r^2sin(2t)
we have
get nice numbers by multiplying by 2/3
4x^2 + 2xy + 4y^2 = -2
group by know facts
4(x^2+y^2)+2xy=-2
use known fact
4r^2+r^2sin(2t)=-2
factor r^2
r^2(4+sin(2t))=-2
divide
r^2=-2/(4+sin(2t))
remember different equation can mean the same thing
I think some of your answers may be correct, but I have not checked them in detail.
are equivalent to my answer
keep in mind we have r^2<0 hence r is and imaginary number
the original equation can be written
3x^2+(x+y)^2 + 3y^2 = -2
clearly this has no solution when x and y are restricted to real numbers.
Rearrange your equation into the form 6(x^2+y^2) + 3xy + 3 = 0 , now do the following substitutions:
x=r cosQ
y=r sinQ
and
r^2 = x^2 + y^2
BJ
