1 Parsec = 3.08568025 × 10^16 meters
  • Thread starter Thread starter VantagePoint72
1 Parsec is defined as 3.08568025 × 10^16 meters, but there are two interpretations of its definition that appear incompatible. The first definition describes the distance at which two objects separated by one Astronomical Unit appear one second of arc apart, while the second defines it as the distance of a star showing a parallax of one second of arc as Earth moves half a year. The confusion arises from the angle used in the second definition, which should be half of the apparent parallax angle. Clarification indicates that the correct interpretation involves using half the angle to accurately estimate distance, resolving the discrepancy. Understanding this distinction is crucial for accurate astronomical measurements.
VantagePoint72
A quick Google search reveals that 1 Parsec = 3.08568025 × 10^16 meters.
I have read two different rephrasings of the definition of a parsec:
1) The distance one would have to be from two luminous objects separated by one Astronomical Unit in order for them to appear one second of arc apart
2) Being a contraction of PARallax SECond, it is the distance of a star that would appear to have a parallax of one second of arc as the Earth completes half a revolution around the Sun
My problem is that these two definitions seem to be incompatible. Please note that I am not trying to disprove one, simply find out where the error in my math is (or perhaps my understanding of these two definitions). My ultra high-tech MS Paint diagrams, attached, illustrate my problem.
Figure 1 shows the first definition:
Length L represents the length of a parsec, and can be easily calculated as it is the perpendicular bisector of the given isosceles triangle. The angle of the right triangle created would be half of an arc second, the adjacent side L and the opposite side 0.5 AU. A quick trig calculation show L to have a length of 206264.8 AU. As one AU=149 598 000 000 metres, one parsec equals 3.085680248 x 10^16 metres, matching the above stated value.
Figure 2 shows the second defintion:
Since the Earth's displacement over 6 months is 2 earth-sun distances, the base of this triangle is 2 Astronomical Units. 1" is the apparent parallax of the plotted star and by the Opposite Angle Theorem we see that theta must also equal 1". Now we have an isosceles triangle like above only while the angle remains the same, the base is twice the length. One need not go through to the steps again (though you may of course do so if you wish) to see that this will give a length for the parsec twice the stated value.
What's going on here?
Astronomy news on Phys.org
It's only an issue of the definition of parallax:
http://encyclopedia.laborlawtalk.com/Image:Stellarparallax2.png
It's half the angle in your diagram.
Your second drawing shows a triangle with a base of 2 AU causing a parallax causing a 1" shift against the background stars. This base is 2 AU so you would need to drop a line through the center straight down to make two right triangles, each with a 1 AU distance.
As to:
This is often stated but is not what they (should) mean. We use that measurement, calculate an angle (parallax) and then use 0.5 of that to make an accurate estimate of distance.
EDIT: Just saw ST's link above, and it clearly shows the angle used to be 1/2 of a six month (1/2 year) orbit.
Thanks guys. That clarifies things. :smile:
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
