Seeking Help on Boolean Logic - I'm New to Computing
  • Thread starter Thread starter skane01
    Computing Logic
A beginner is seeking mentorship to understand Boolean logic as part of their computing course. Boolean logic involves combining elements in various ways, often using operators like "and," "or," and "not." An example provided illustrates how to use Boolean conditions in code to check for multiple phrases. The discussion highlights that Boolean concepts can apply to different fields, such as light mixing and even bubble foam. Understanding these principles is essential for grasping more complex computing topics.
skane01
To Who Ever Is Willing To Help
I,m am looking for a mentor to help me understand boolean. I do not poccess any knowledge of physics as yet but have just begun a computing course for beginners and any help would be much appreciated.
Yours Sincerely
S. Kane
Mathematics news on Phys.org
Boolean is when something can merge into combinations or a specified combination. Using (x) or ((x)x) or (((x)x)x)
If ((InStr(1, String, "WATS UR BIRTHDAY", 1) > 0 Or InStr(1, String, "WHATS UR BIRTHDAY", 1) > 0) Or InStr(1, String, "WHAT'S UR BIRTHDAY", 1) > 0) Then Response = "May 1st" This example of using Parenthases to boolean the code as either or either and or all or in combination.
Its a way to mix and match in many different combinations.
For instance, Using three shades of light, RED YELLOW BLUE will produce White light if the RED, YELLOW, BLUE merge to one point.
It really depends on which area you are using Boolean.
Bubble foam is Boolean as well.
Hope this helps.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
