0 = t(7.8 x 10² m/s - 4.9 m/s² t)
  • Thread starter Thread starter viet_jon
The discussion revolves around solving a quadratic equation related to motion, specifically involving time (t) in the context of physics. The original poster expresses confusion about isolating the variable t when it appears in the equation multiple times.
  • Participants discuss factoring the equation and the implications of having t appear twice. Some suggest using the quadratic formula, while others propose simpler methods of isolating t. There are questions about the meaning of variables and the derivation of the equation from physics principles.
The conversation is ongoing, with various methods being explored to understand the problem. Some participants have provided guidance on factoring and recognizing solutions, while others are still seeking clarity on the mathematical concepts involved.
There are mentions of the original poster's long absence from formal education, which may contribute to their confusion. Additionally, there are references to the quadratic formula and its application, indicating a need for foundational understanding in algebra and physics.
viet_jon
[SOLVED] 0 = t(7.8 x 10² m/s - 4.9 m/s² t)
0 = ( 7.8 x 10² m/s ) x t + ½ x (-9.5 m/s²) x t²
I have time, represented by t in the equation twice...how would I figure out what time is? This is probably simple math, but being out of school for 7 years now, someone please refresh my memory.
0 = t
or 0 = (7.8 x 10² m/s - 4.9 m/s² t)
4.9 m/s² t = 7.8 x 10² m/s
t = (7.8x10²m/s) / (4.9 m/s²)
= 1.6 x 10² s
I didn't understand you, you already have the two values for time. These represent the two times at which your condition is met.
0 = t
= 1.6 x 10² s
you have your two times... they're written right there
opps...sorry guys...forgot to mention, the answer shown is not my answer, it's the answer in the back of the book.
I don't understand how they got it. I only know how to isolate 't' (time), if there's one variable. i.e. 1 = t + 2...isolated would be 1 - 2 = t.
In the original equation, there's 't' twice...how would I isolate that?
If we leave the equation in a symbolic form and factor out a t we get:
0 = t(v+0.5gt)
When does the RHS = 0?
ax^2+bx=0 you could consider the equation like that if it helps...
Let's drop all the units for a while, then your equation is of the type
[tex]0 = a t^2 + b t[/tex]
where a, b are just numbers and you want to solve for t.
You can use the "no-thinking-involved" way and just plug it into the abc-formula, which says that the solutions for
[tex]0 = a t^2 + b t + c[/tex]
in general are
[tex]t = \frac{ - b \pm \sqrt{b^2 - 4 a c} }{2 a}[/tex]
(if you choose the plus or the minus you get two solutions).
But in this case there is an easier way, and that's noticing that you can bring a t outside the brackets:
[tex]0 = (a t + b)t,[/tex]
if you work out the brackets you'll see that this is the same as the original equation.
Now you have a product of two things, namely t and a t + b. When is a product of two numbers zero?
0 = t(v+0.5gt)
now I'm more confused...what's v? and what's gt?
Your equation 0 = ( 7.8 x 10² m/s ) x t + ½ x (-9.5 m/s²) x t²
was derived from [tex]x_f =x_0+v_0t+\frac{1}{2}gt^2[/tex]
v and g are just constants (7.8 x 10² m/s for v and -9.5 m/s² for g)
in general are
where does c come from?
and how does 0= at2 + bt + c
work out to be
i've never learned this math before, is there a name for this? I tried googling, but don't know what this is called.
work out to be[tex]t = \frac{ - b \pm \sqrt{b^2 - 4 a c} }{2 a}[/tex]
?i've never learned this math before, is there a name for this? I tried googling, but don't know what this is called.
It's called the quadratic formula -- basically it's used to solve quadratic equations (equations that have a variable to the second power t^2)
What's that highest level of math you've taken?
grade 12 ... but that's 7 years ago.
been dicking around ever since, forgot everything.
i'm taking Uni prep Physics grade 12 right now.
cool...quadratic formula...going try google, see if there's a tutorial.
Ah ok... Well there's an easier way then using that formula:
0=(7.8 x 10² m/s) x t + ½ x (-9.5 m/s²) x t²
Would you agree that we can factor out a "t" and get:
0=t((7.8 x 10² m/s) + ½ x (-9.5 m/s²) x t)
Would you also agree the anything multiplied by 0 will equal 0?
So if t=0 we get:
0=0((7.8 x 10² m/s) + ½ x (-9.5 m/s²) x 0)
0=0(7.8 x 10² m/s + 0)
0=0
So we know that t=0 is a solution. But that's not the only solution.
Would you agree that 0=t((7.8 x 10² m/s) + ½ x (-9.5 m/s²) x t) when
(7.8 x 10² m/s) + ½ x (-9.5 m/s²) x t = 0
since that would give us 0 = t x 0 which is 0
Ah, since you were asking a physics-based question, I assumed a high-school level of mathematics. So I guess you have some reading up to do :smile: (as a side note, if you want to really learn algebra thoroughly, solving quadratic equations may not be the easiest way to start. )
So if t=0 we get:
0=0
my heads spinning on the physics alone. I'm going to try to figure out quadratic equations before I attempt other methods.
yes, lots of reading...sigh...!
before this lesson, I ran into something I didn't know...trigonometry. Had to download ebooks to figure it all out. I got most the basics down now.
now quadratic equations...sigh!
I'd like to comment on how wicked this forum is. Thnkx guys/...I really appreciate all the help. I hope this forum stays as active as it is now.
cheers...got lots of reading to do.
got a little backround, but a little stuck.
0 = ( 7.8 x 10² m/s ) x t + ½ x (-9.8 m/s²) x t²
using
should be ?
a= -4.9 m/s² t²
b= 7800 m/s
c= ?
what would c be for this formula? would I just leave it out?
a = -4.9 m/s^2
b = 780 m/s
c = 0 -- since we don't have a "c term"
wicked!
it works! problem solved...!
The advantage of that formula is that it always works for a quadratic equation. All you have to do is bring it to the form [itex]ax^2 + b x + c = 0[/itex] by adding/subtracting terms on both sides of the equation, identify the a, b and c and plug them in.
The disadvantage is, as you might have noticed by now, that some formula's are easier to solve without it. For example, you can solve
[tex]a t^2 + b t = 0[/tex]
by noticing that you can bring a t outside the brackets (as in the problem you originally posted):
[tex](a t + b) t = 0 \Rightarrow t = 0 \text{ or } a t + b = 0 \text{ so } t = - b / a[/tex]
or
[tex]t^2 - c = 0[/tex]
by just bringing the c to the other side and taking square roots.
But if you don't see such a method, the quadratic formula always works.
9K
