1000 Hz corresponds to I = 10^-12
  • Thread starter Thread starter colonel
To find intensity (I) for frequencies other than 1000 Hz, it's crucial to clarify what is meant by intensity and its units, which are watts per square meter. There is no direct relationship between frequency and intensity, as frequency is context-dependent and varies with the specific situation and type of radiation involved. For instance, a tuning fork at 1000 Hz primarily emits sound at that frequency, while a VLF antenna operates within a narrow band around 1000 Hz. Additionally, blackbody radiation can vary widely in spectrum based on the temperature of the emitting object. Understanding the physical context is essential for accurately determining intensity across different frequencies.
colonel
If 1000 Hz corresponds to I = 10^-12 , then how do you find I for other given frequncies?
You need to tell us what you mean by I. Units would be helpful.
I would be intensity, in watts/squared metre.
There is no intrinsic relationship between frequency and intensity. Frequency depends entirely on the situation and the spectrum of radiation. For example, a tuning fork designed to vibrate at 1000 Hz will emit virtually no other sound at different frequencies. A VLF antenna designed for 1000 Hz will emit little outside a narrow band of EM frequencies centered on 1000 Hz. Blackbody radiation may be distributed over a very broad or relatively narrow spectrum depending on the temperature of the emitting object
First, are you thinking of acoustic waves, EM waves or something else? Perhaps you're thinking of energy of photons rather than intensity? What's the physical situation?
