Direction of heat? Hot to cold Please explain.
Heat flows from hot to cold, which is a fundamental principle in thermodynamics. This direction is driven by the natural tendency of systems to reach equilibrium and minimize energy differences. For example, a hot cup of coffee cools down as it transfers heat to its cooler surroundings, raising their temperature. This process reflects the broader concept that energy naturally disperses from areas of higher concentration to lower concentration. Understanding this principle is essential for grasping basic thermodynamic concepts.
Mallignamius
Direction of heat? "Hot to cold..." Please explain.
During a college prep class last year, my physics teacher said something about the direction of heat. He asked a student, "Which direction does heat go? From hot to cold, or cold to hot?" I'm pretty sure that's what he asked.
I wish I had spoken up, but I didn't. Now I'm stuck on this. Can you explain this "direction"?
direction of flow of heat is from hot to cold conventionally .it is due to the reason that every system in nature tries to attain minimum energy.A hot cup of coffee gets cool after sometime or stated another way "the temperature of surronding rises".Its up to u how do u look at nature.
