Why Does Glass Become Brittle After Heating?
  • Thread starter Thread starter bw800402
    Glass Heating
Heating glass bottles to high temperatures in a bonfire causes them to change shape, but upon cooling, they become extremely brittle. This brittleness results from improper cooling techniques. While annealing typically involves heating glass and then cooling it uniformly to relieve internal stresses, rapid cooling or quenching can lock in these stresses, leading to increased brittleness. The discussion highlights that the molecular structure of glass changes during heating, potentially increasing silica content if sodium is burned out, which raises the softening point but does not enhance strength. It is emphasized that strength and brittleness are related properties; treatments that increase strength often reduce ductility, making materials more prone to breakage under stress. Proper cooling methods are crucial for maintaining the integrity of glass after heating.
bw800402
After heating some glass bottles to a very high temperature with a bonfire the bottles changed shape as you would expect molten glass to do, but once the bottles returned to ambient temperature they were extremely brittle. What is happening to cause this? I read that annealing requires heating glass then cooling it very quickly and this is supposed to strengthen the glass. What are the changes in molecular structure that leads to the the weakening of the glass in this case?
Chemistry news on Phys.org
"WORNG." Cool slowly, and uniformly to allow the material to relax --- a quick quench locks in all sorts of stresses, resulting in easy breakage.
The only change in chemistry from heating is that you can burn the sodium out of a glass, leaving you with a higher silica content, slightly higher temperature softening point.
You're using very specific terms in very general ways. Strength and brittleness are not "opposite" properties. In fact, they usually go hand in hand. Any heat treatment that makes something stronger (gives it a higher breaking strength) typically makes it more brittle (lowers the strain at failure).
So how did you cool the glass?
Gokul is right, a diamond is really strong, but it's also really brittle. Which is why you can break diamonds with a hammer. On the other hand elastic bands are fairly weak and if you stretch them enough it breaks without much force, but they're not brittle at all, you can fold it and bend it and nothing will happen to it.
