Understanding the "Bifurcated fan": Examples and Illustrations
  • Thread starter Thread starter kach22i
    Fan
The term "bifurcated fan" refers to a fan design where the airflow is split into two distinct channels, often used in applications requiring separation from hot gases. Examples include axial fans with a centered engine pod that can have front intake and varying thrust configurations, such as rear or side thrust. The design can also feature opposing intakes with exhaust positioned at different angles, or a remote drive system. The term "bifurcated" itself means "split into two forks," indicating the dual airflow paths created by the fan's shroud. Bifurcated fans are particularly useful in scenarios where shielding from heat is necessary.
kach22i
"Bifurcated fan"
What does the term "Bifurcated fan" actually mean?
Please provide a link to some examples and or illustrations which clarify the term.
The images and text I've seen using Google image search
"Bifurcated fan" have shown.......
1. Axial fan with centered engine pod; front intake, rear thrust.
2. Axial fan with centered engine pod; front intake, right and or left
thrust (sides).
3. Axial fan front and back (possible common shaft) opposing intakes,
with exhaust/thrust top and bottom or right and left (sides).
4. Axial fan with remote drive (via belt) including combinations above
(1,2, & 3).
Like many architectural terms (my thing) you may not obtain it's true meaning and
context from regular dictionaries. I will assume "Bi" means split in
two somehow. That could mean split thrust, split intake or split flow
by engine placement.
What the heck is "Furcated" by it's self?
Bifurcated means "split into two forks" or "branches", so snakes have bifurcated tongues.
As for a bifurcated fan, well the shroud in which the fan sits splits into two forked channels which carry the air, so there is a void behind the axis of the fan itself. Google images results are pretty self explanatory. They're used where the motor needs to be shielded, from hot gases for instance.
http://images.google.co.uk/images?hl=en&q=bifurcated fan&sa=N&tab=wi
Thank you.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
9K
10K
9K
