Solve Volumetric Strain | Question 3 on http://img201.imageshack.us/my.php
  • Thread starter Thread starter johnboy14
    Strain
To solve for volumetric strain, the relationship is defined as the change in volume divided by the original volume. The volumetric strain can be calculated using the sum of the principal strains, represented as Ev = Ex + Ey + Ez. In the given problem, since it is in a state of zero shear, the principal stresses correspond to the principal strains. The calculated volumetric strain is approximately 6.5 x 10^-4, which aligns closely with the expected value of 6.8 x 10^-4. Understanding the three-dimensional stress-strain relations involving Young's modulus (E) and Poisson's ratio (ν) is essential for accurate calculations.
johnboy14
How do I solve the following block to find the volumetric strain. Its question 3 on the link
http://img201.imageshack.us/my.php?image=file0001pf0.jpg
I know that volumetric strain is equal to change in volume EV/ origninal volume(V)
Is Ev = Ex + Ey + Ev equal to volumetric strain.
I was told that the volumetric strain should be about 6.8 x 10^-4
Any help would be appreciated people.
I am used to seeing volume dilation as the sum of the principal strains.
D = [\epsilon_1 + \epsilon_2 + \epsilon_3] = J_1 where J_1 is the first strain invariant.
I would tackle the problem that way. Calculate the principal strains and add them together.
EDIT: After looking at the problem, it is in a state of zero shear. Therefore \sigma_x, \sigma_y and \sigma_z are going to be the principal stresses. So, if you calculate the strains from the principal stresses you will be calculating the principal strains. Things should be pretty straight forward. I ended up calculating 6.5 x 10^{-4}
Do you know the 3 dimensional stress-strain relations that involve E and \nu?
yes I do
E = 200x10^9
v = 0.3
Those are constants, not the relations themselves. I meant the entire relations, i.e. equations.
Hint: There are three equations you're looking for and each equation will have one strain element and all three stress elements.
