How do light, radio, and sound waves work together in televisions?
  • Thread starter Thread starter physics246
    Physics Television
Televisions utilize physics to synchronize light, radio, and sound waves, with information transmitted as electromagnetic waves. The sound and image are produced inside the television based on electric signals received through cables from the antenna. Although light travels faster than sound, the minimal delay in sound reaching the viewer's ears—about 0.01 seconds at a distance of 10 feet—is imperceptible. Sound waves are converted into electromagnetic waves during transmission, allowing for effective communication. Ultimately, both sound and image are delivered to the viewer in sync thanks to these processes.
physics246
How does physics play a role in televisions with respect to light waves, radio waves, and sound waves. Also, if the speed of light is faster than the speed of sound, why does the picture and sound arrive at sync in a television. I just need to know a little bit about the basis of a television, not too much.
Thank you
If the sound as you hear it from the television had actually been transported in the shape of a sound wave from the sender, then a lot of eardums on the way would have exploded.
The information necessary to construct the sound inside your television set is carried by electro-magnetic waves just as the information necessary to construct the image on your television set.
That is, actual image and sound production happens within your television set, on basis of the information carried to it as a sequence of electric signals in the cable; that sequence again having been started at your antenna on receiving the incoming EM wave.
Speed of sound is roughly 1000 ft/sec., so if you are 10 feet away from the screen, it arrives in about .01 sec - you can't tell the difference.
1. Is it possible to convert sound waves (longitudinal) into electromagnetic waves (transverse)
2. I know that the picture travels as an electromagnetic wave to get from the station to the T.V., but when it gets from your monitor to your eyes, how does it travel.
1. Yes. That coversion process is happening when the journalist speaks into his microphone. The sound waves hitting the microphone triggers the apparatus to deliver its signals onwards.
2. As waves in the spectrum of visible light.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
