Breaking Records: French National Railroad's TGV Acceleration
  • Thread starter Thread starter ahsanmhamid
    Acceleration
The French National Railroad's TGV train holds the world speed record for passenger trains at 325 km/h and requires 1.35 km to stop. To find the braking acceleration, one must apply kinematic equations for constant acceleration, as the problem involves only horizontal components. Users are encouraged to identify the appropriate equation based on the initial velocity, stopping distance, and final velocity. The discussion emphasizes the need to show work for homework-related queries. Understanding these concepts is crucial for solving the problem effectively.
ahsanmhamid
The French National Railroad holds the
world's speed record for passenger trains in
regular service. A TGV (tres grand vitesse,
or very great speed) train traveling at a speed
of 325 km/h requires 1.35 km to come to an
emergency stop.
Find the braking acceleration for this train,
assuming constant acceleration. Answer in
units of ms^2.
Welcome to the forums. For homework/coursework type questions you must show some work before we can help-- forum rules. So, what thoughts do you have on the question?
i need some help setting up the problem. I don't unders the horizontal and vertical componenets. Also what formula do i use?
Well, there are only horizontal components in this question. You are told an initial velocity, a stopping distance, and a final velocity. You are also told that the acceleration is constant, and thus you are indirectly told to use the kinematic equations for constant acceleration. See this webpage for a list of the equations http://hyperphysics.phy-astr.gsu.edu/hbase/mot.html#mot1
Now, can you pick one of these equations to use?
