2 carts, a string, what is the work done?
The discussion revolves around calculating the work done on a cart by a string in a system involving two masses connected over a frictionless pulley. Initially, the user incorrectly calculated the work as 29.4J, assuming the force on the cart was equal to the weight of the hanging mass. Through guidance, they learned to derive the tension in the string and the acceleration of the system using Newton's second law, leading to the correct tension of 19.6N. The final calculation for work done on the cart was determined to be 19.6J after correcting the equations and understanding the relationship between the two masses. The user expressed gratitude for the clarification and confirmed their understanding of the process.
mujadeo
A cart of mass M1 = 6 kg is attached to a block of mass M2 = 3 kg by a string that passes over a frictionless pulley. The system is initially at rest and the table is frictionless. After the block has fallen a distance h = 1 m, What is the work Ws done on the cart by the string?
heres how it looks...
http://www.imagination3.com/LaunchP...7_211715035_342819690_usa&transcript=&_lscid=
I know work is F * distance moved, and i can surmise that M1 moves the same distance as M2 (1m) cause theyre contrained by the string.
I know that force on M2 is 3 * 9.8 = 29.4N,
No friction so force on M1 (pulling horizontally) is also 29.4N
distance is 1 meter, so 29.4N * 1m = 29.4J
= wrong!
Please help!
]thanks
= wrong!
Please help!
]thanks
Hint: The force acting on M1 is not the weight of M2... Draw the freebody diagram of M1... and also draw the freebody diagram of M2... label all the forces... What are the forces acting on M1... what are the forces acting on M2?
Yes i drew fbd for both, so i need to find the tension in string (on M1).
But I don't understand why force on m1 is not downwhard force (weight) on m2?
pully and surface are frictionless
strings are massless
i don't get it?
i don't get it?
You would be right if the acceleration was 0... But that's not the case here. You have two equations with two unknowns... T (tension in the string) and a the acceleration (which is same for both carts).
why do i need the acceleration i just need the tension in the string don't i?
As in the last post I looked at you simply aren't writing the equations down. If you do, then what learningphysics is telling you will be much clearer.
That's right, you don't need to calculate acceleration... But your two equations will have the two variables tension and acceleration. You only need to calculate the tension...
As Dick suggested, you should go ahead and write out the equations... it will make things much clearer... what do you get for your two equations?
M1
Fx = T = ma (no other x force cause no friction)
Fy = 0 (not moving vertically)
mujadeo said:
M1
That's right... and what equations do you have for M2?
Fx = 0 (not moving horiz)
Fy = T-W (mg) = ma
so my 2 unkonws are T and a, right?
Fy = T-W (mg)
Yes. I'd write it like this...
Fy = M2*a, therefore
T - M2*g = M2*a
and your equation for M1 from before is:
T = M1*a
So you have these 2 equations (the other 2 equations Fx=0 and Fy=0, don't help to solve the problem):
T - M2*g = M2*a
T = M1*a
And from here you can solve for T.
Exactly. :smile:
T-mg = ma (x)
T = ma (y)
is this ok so far?
mujadeo said:
T-mg = ma (x)
T = ma (y)
is this ok so far?
Yes, but be careful about the masses... write M1 and M2 instead of just m so that you aren't mixing up the masses...
OK so..
T-M1g = T
i combined equations but the Ts will just cancel
mujadeo said:
T-mg = ma (x)
T = ma (y)
is this ok so far?
It should be:
T - M2g = M2a
T = M1a
mujadeo said:
OK so..
T-M1g = T
You mixed up M1 and M2...
learningphysics said:
It should be:
T - M2g = M2a
T = M1a
M2a + M2g = M1a
M1a - M2a = M2g
a(M1-M2) = M2g
a= M2g / (M1-M2)
a = 9.8m/s/s
F=ma
58.8N = 6*9.8 (of M1)
W=Fx
58.8N * 2m = 117.6J
doesnt add up though?
mujadeo said:
M2a + M2g = M1a
M1a - M2a = M2g
a(M1-M2) = M2g
a= M2g / (M1-M2)
a = 9.8m/s/s
F=ma
W=Fx
58.8N * 2m = 117.6J
Your original description says 1m, so it should be 58.8N * 1m = 58.8J. Is the answer 58.8J?
your right --thanks
but 58.8J is not right either.
M1 = 6kg
M2 = 3kg
h = 1m
I'm sorry mujadeo, I made a mistake... That second equation should be:
T - M2g = -M2a (taking up as positive and down as negative)...
So
T - M2g = -M2a
T = M1a
-M2a + M2g = M1a
M1a + M2a = M2g
a(M1+M2) = M2g
a= M2g / (M1+M2)
a=3.27...
so T = M1*a = 6*3.27= 19.6N
So work = 19.6N*1m = 19.6J... hope it's right.
ah. add the masses.
yeah 19.6J is right, and i do undersant the whole process now
thanks alot!
mujadeo said:
ah. add the masses.
thanks alot!
You're welcome. :smile: Do you see why I had to switch the sign? Since we labeled 'a' as being the acceleration of M1 to the right, we have to label 'a' as being the downward acceleration of M2... for consistency... then taking up as positive and down as negative... the acceleration of M2 is '-a'...
