Skateboard Ramp Kinematics Practice Problem
  • Thread starter Thread starter jehan4141
    Kinematics
The skateboarder launches off a ramp at 6.6 m/s at a 58° angle from a height of 1.2 m. The maximum height reached above the ground is calculated to be 2.798 m. At the highest point, the skateboarder is horizontally 1.997 m from the end of the ramp. The calculations for vertical and horizontal components of motion are confirmed to be correct. The problem-solving approach effectively applies kinematic equations to determine the skateboarder's trajectory.
jehan4141
This is an even problem with no solution provided. My quiz is Monday. Could somebody check this practice problem for me?
A skateboarder shoots off a ramp with a velocity of 6.6 m/s, directed at an angle of 58° above the horizontal. The end of the ramp is 1.2 m above the ground. Let the x-axis be parallel to the ground, the +y direction be vertically upward, and take as the origin the point on the ground directly below the top of the ramp.
(a) How high above the ground is the highest point that the skateboarder reaches?
(b) When the skateboarder reaches the highest point, how far is this point horizontally from the end of the ramp?
Vo = 6.6 m/s
Voy = Vosin58 = 6.6sin58
Vox = Vocos58 = 6.6cos58
Vy = 0 m/s at the highest point
Vy2 = Voy2 + 2ay
y = ( Vy2 - Voy2 ) / 2a
y = [0 - (6.6sin58)2] / (2*-9.8)
y = 1.598353244 m
y + 1.2 = 2.798 m
VFy = 0 m/s
Voy = 6.6sin58
VFy = Voy + at
t = ( VFy - Voy ) / a
t = ( 0 - 6.6sin58 ) / -9.8
t = 0.5711344321 s
Vx = x/t
x = Vxxt = (6.6cos58)(0.5711344321)
x = 1.997 m
They all agree with my answers.
Thank you!
