What is the initial velocity of a flea that jumps to a maximum height of 0.550m?
  • Thread starter Thread starter Scrum
    Jump
The initial velocity of a flea that jumps to a maximum height of 0.550 meters is calculated to be 3.28 m/s. This is derived using the kinematic equation, where the final velocity at the peak height is zero. The time the flea spends in the air is determined to be approximately 0.670 seconds, accounting for both ascent and descent. The calculations confirm the use of kinematic principles effectively. The discussion emphasizes the importance of understanding motion under gravity in solving such problems.
Scrum
[SOLVED] Just Checking
In this problem, you will apply kinematic equations to a jumping flea. Take the magnitude of free-fall acceleration to be 9.80 .
A flea jumps straight up to a maximum height of 0.550m . What is its initial velocity Vsub0 as it leaves the ground?
Express your answer in meters per second to three significant figures.
Since my givens are
x = .550m
[Vsub0] = unknown
[Asubx] = =9.80
Hopefully [Vsubx]^2 = [Vsub0x]^2 + 2[Asubx] * (X-[Xsub0])
Vsubx is the final velocity, which at the max height is 0, and Xsub0 is just 0 as that's where it starts so I just plug the rest in
0^2 = [Vsub0x]^2 + 2[-9.80]*(.550)
0 = [Vsub0x]^2 -10.78
10.78 = [Vsub0x]^2
Sqrt(10.78) = 3.28 m/s
I think this is correct but i want to check as the homework system is somewhat unforgiving
Yep. Correct.
Now that I completed that the homework is asking me another question.
How long is the flea in the air from the time it jumps to the time it hits the ground?
Express your answer in seconds to three significant figures.
x = .550m
[Vsub0] = 3.28m/s (ans to 1)
[Asubx] = =9.80m/s^2
t= unknown
X-[Xsub0] ={ ([Vsub0x] + [Vsubx])/2 } t
3. The Attempt at a Solution
x - xsub0 is .550m because initial position is 0 and final is .550m
.550m ={ ([Vsub0x] + [Vsubx])/2 } t
sub in vars
.550m ={ ([3.28m/s] + [0])/2 } t
.550m ={ 3.28/2 } t
.550m = 1.64m/s * t
.550 / 1.64 = .335
ans = .335 to go from gound to top of parabola
.670 to go all the way? Just checking again, this new to me.
Use time of fall = time of rise. Makes things easier.
h = 1/2 gt^2 => 0.55 = 0.5*9.8*t^2 => t = 0.33 => 2t = 6.7.
