220V European treadmill on USA 110V
  • Thread starter Thread starter carlopiano
    Usa
The discussion revolves around the feasibility of using a European treadmill rated at 230V in the United States, where the standard voltage is 110V. Participants explore the use of transformers or converters, electrical compatibility, and safety considerations related to wiring and power ratings.
  • Experimental/applied
  • Some participants suggest that the treadmill may be wired directly to a 230V outlet, depending on local wiring configurations.
  • Concerns are raised about the differences in electrical safety standards between Europe and the US, particularly regarding grounding and insulation.
  • There is a discussion about the treadmill's power rating, with some noting that the 3.5 HP rating may indicate a higher wattage than the stated 1850W.
  • Participants mention that using a correctly specified transformer (autotransformer) is possible but may be costly and heavy.
  • Some argue that the frequency difference (50Hz vs. 60Hz) may not significantly impact the treadmill's operation, especially if it uses a variable speed DC motor.
  • One participant suggests contacting the manufacturer for verification of compatibility with US power standards.
  • Concerns are raised about the potential for circuit breakers to trip due to high startup power demands of the treadmill.
  • Some participants propose that purchasing a transformer is the simplest solution, while others express skepticism about the feasibility of using the treadmill on a standard 110V outlet without proper precautions.
Participants express a range of views on the compatibility of the treadmill with US power systems, with no clear consensus on the best approach. Some agree on the potential use of a transformer, while others caution against the risks involved without proper electrical expertise.
Participants highlight limitations related to electrical safety standards, potential differences in motor design, and the need for professional evaluation before proceeding with any modifications.
carlopiano
Can someone help me? Is there a way to use my European treadmill (3,5HP, 230V AC, 50/60Hz, 1850 WATT) here in US using a transformer/converter? thank you!
Welcome to PF!
It may be wirable directly. 230V or thereabouts is a pretty normal American voltage, but it depends on the specific wiring of where you live. Most single homes use split-phase 120/240V and most apartments/condos use 120/208 single/2 legs of a 3-phase.
But...this isn't something you're likely to be able to wire yourself. And you certainly cannot use a standard 120V circuit for this load. It's way too big (also, 3.5 HP is 2600W, not 1850).
Yes, it may run on 120/240V. But, I wouldn't suggest that unless someone that knows about electrical safety standards looks at the construction. In Europe, the 230V service is ground referenced, i.e. one of the current carrying conductors is neutral and near ground potential. In the US 240V single phase is normally two 120V (wrt ground) conductors out of phase. There may be insulation differences in transformers, motors, etc. that matter. They may not have overcurrent protection in the neutral side, which you would need. I would bet it's OK, but I wouldn't bet someone's house or life on it without some examination.
https://electrical-engineering-portal.com/19-essential-information-you-can-find-on-motor-nameplate#17 are weird complicated. That's probably a peak HP rating vs. a maximum average power rating under some usage conditions.
You can definitely run it from a correctly specified transformer (autotransformer, actually). But, it will be big, heavy and expensive. An EE could look inside and determine what is and isn't compatible and how to convert it. For example, it may be better to replace the motor than buy a big transformer, or not, IDK. I would guess the answers range from simple to too hard to do.
Also, the change from 50Hz to 60Hz will reduce the motor's power, which probably doesn't actually matter much.
If it's still in Europe, I'd just sell it and buy a used one here that just plugs in the wall.
I expect it would be fitted with a variable speed DC motor, driven by an H-bridge, so mains frequency would not be important.
Thank you all. Unfortunately it is already in the US, and I understand that it is very very complicated, also because I should ask an electrician who knows both European and American standards. About the HP and Watts, I attach the manual information about that.
DaveE said:
Yes, it may run on 120/240V. But, I wouldn't suggest that unless someone that knows about electrical safety standards looks at the construction. In Europe, the 230V service is ground referenced, i.e. one of the current carrying conductors is neutral and near ground potential. In the US 240V single phase is normally two 120V (wrt ground) conductors out of phase. There may be insulation differences in transformers, motors, etc. that matter. They may not have overcurrent protection in the neutral side, which you would need. I would bet it's OK, but I wouldn't bet someone's house or life on it without some examination.https://electrical-engineering-portal.com/19-essential-information-you-can-find-on-motor-nameplate#17 are weird complicated. That's probably a peak HP rating vs. a maximum average power rating under some usage conditions.You can definitely run it from a correctly specified transformer (autotransformer, actually). But, it will be big, heavy and expensive. An EE could look inside and determine what is and isn't compatible and how to convert it. For example, it may be better to replace the motor than buy a big transformer, or not, IDK. I would guess the answers range from simple to too hard to do.
A converter like this one (10000W)?
https://www.amazon.com/gp/product/B01J923F5Q/?tag=pfamazon01-20
Let me try from a different angle: the fact that it says 60hz tells us with near certainty that it can run on American power.
But sure: it's easy enough to contact the manufacturer to verify.
carlopiano said:
The problem is that at full speed and maybe even right when you turn it on, it will likely trip your circuit breaker. 1850W is just above the limit, but if it draws like a 3.5 HP at startup, that's 2900W.
Or worse if that doesn't account for efficiency and power factor.
phyzguy said:
The simplest thing is to just buy a transformer and plug it in. Something like this one from Best Buy. I doubt the 50Hz/60Hz difference will be a problem.
https://www.110220volts.com/ac-3000...MIj-qmodOr8gIVkTytBh0QQwLsEAQYByABEgJlHfD_BwE
Wow, those are a lot cheaper than I expected. I guess I'm out of touch. This is definitely what I would do; the easiest way by far. You'll never get a 240V outlet where you want it for $120.
So, you also think that with this I can use my treadmill from a 110V outlet?
20A circuit, yes. 15A circuit, maybe not, not if it draws full power. Try to avoid a 20A circuit that has other significant loads at the same time (microwaves, hair driers, etc) or you may trip the circuit breaker.
Thank you all for your support!
  • · Replies 22 ·
17K
  • · Replies 41 ·
19K
