(23)/(120x) = 1/5. Solve for X
  • Thread starter Thread starter 939
To solve the equation (23)/(120x) = 1/5, multiply both sides by 120x, ensuring that x is not zero. This simplifies to 23 = (120x)/5. From here, you can solve for x using standard algebraic methods. Alternatively, the equation can be approached through cross multiplication, leading to the same result. Understanding these methods clarifies how to handle variables in the denominator effectively.
939
How is it done?
Having to solve for X when X is in the denominator really confuses me. Please help!
939 said:
How is it done?
Just multiply both sides by 120*x and remember that this works as long as 120*x =/= 0 which means
that x=/=0 in your final solution because dividing by zero is not defined.
Likes 1 person
Remember that
a\cdot\frac{b}{c} = \frac{a}{c}\cdot b =\frac{ab}{c}
(The dot means multiply) so if we multiply
\frac{23}{120x}=\frac{1}{5}
by the denominator in the left fraction (which is 120x) then we get
120x\cdot\frac{23}{120x}=120x\cdot\frac{1}{5}
And now we can cancel 120x from the left side because
120x\cdot\frac{23}{120x} = \frac{120x}{120x}\cdot 23 = 1\cdot 23=23
So we now have
23=\frac{120x}{5}
Now you can solve the rest in the usual way you've been solving equations.
Also, keep in mind that you can have just multiplied through by x rather than 120x.
Likes 1 person
This problem looks like it was made for cross multiplication, is that what they're teaching you right now?
Likes 1 person
As an alternative, if two fractions are equal, then their reciprocals are equal.
IOW, if a/b = c/d, then b/a = d/c, barring of course the possibility that any of the numbers are zero.
In the context of this problem, you can rewrite 23/(120x) = 1/5 as 120x/23 = 5.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
