Measuring the Diameters of the Moon at Perigee and Apogee
  • Thread starter Thread starter crystalplane
    Measuring Moon
To measure the diameters of the Moon at perigee and apogee, the user recorded values of 6.00 cm and 13.00 cm, respectively, but expressed uncertainty about these measurements. The discussion emphasizes the need to find a formula that connects eccentricity directly to apogee and perigee distances, rather than using semi-major and semi-minor axes. A suggested formula for calculating eccentricity is e = (1 - b²/a²)^(0.5), but confusion remains regarding its application. Participants recommend double-checking the diameter measurements, as they appear inconsistent. Accurate measurements and the correct formula are crucial for determining the Moon's orbital eccentricity and comparing it to the known value of 0.0549.
crystalplane
the image below shows the Moonat perigee and apogee. Measure the diameters for the two, and determine the ratio between perigee and apogee idstance.Based on your result, what is the eccentricity of the Moon'orbit? Compare your value with the Moon' s mean orbital eccentricity(e= 0.0549)
i have already measured diameters of apogee and perigee, 6.00cm and 13.00 cm(i am not sure about these two numbers.)
based on the formula e= (1-b^2/a^2)^0.5,where b is the sei-minor axis...i am very confused about this question.
any help is appreciated.
You need to find a formula that relates eccentricity to apogee and perigee rather than to the semi-major and semiminor axi. (Or find a formula that relates the apogee and perigee to the semi-major and semi minor axi.)
I'd also double check your measurements. (they seem a bit off to me.)
